Strang Brakes On All 4 Corners and Not Stopping Well.
Alright, I have just installed a full set of Strange Drag brakes on all corners. With a new master cyl., SJM line lock kit, stainless lines, and have bled, and bled, and bled, and bled, and..... well you get the idea. They do not stop hardly at all!!! It takes 2 pumps of the peddle before it will start stopping the car. Is there something else that I have over looked? Any help will be greatly appreciated!
-Coleman
-Coleman
It's a factory master cylinder. What is this "redrilling the brake pedal" you speak of?
Thanks for the replies guys!
-Coleman
Something is wrong, bleed the master and make sure and bleed the top bleed screws on the calipers.
I use one of those little bottles that hangs on with a magnet and the hose connects to the bleeder screw and just keep pumping until no bubbles are in the line (9.00 at advance auto). Start at the furthest caliper from the master.
Also make sure the calipers are centered on the rotor.
Brakes should feel no different then stock as far as initial stopping power and pedal height.
Is there another way to bleed the master cyl, than bench bleeding it? I bench bled the master before I put it on the car. Then bled the brake system out of the top ports just like you stated above kp.
-Coleman
-Coleman
Bench bleed should be fine, if you have some air trapped somewhere the 'pump, hold pedal down and open bleeder' method doesnt work all the time, especially starting with an empty system. The little bottle method just leaves the bleeder open and you can watch the bubbles in the line so you know when you have clear fluid going through and no air. A little air in any of the lines/ABS block/master and the brakes will feel like crap.
So what you are saying is, get the little bottle, fill it up enough so that the tube is sumerged in brake fluid, and just pump the brakes until there is no bubbles coming out of the tube.
You can use a vacuum bleeder or pressure bleeder as well, but the cheap little 'one man bleeder' kit works just fine. Also as stated you have to bleed the inner and outer top bleeder screw on each caliper.
*Update*
Bled the inside ports on all 4 calipers and man WHAT A DIFFERENCE!!! That was the whole problem. I haven't got to drive the car down the road yet but, in the parking lot these bad boys freaking stop on a dime!! With very little peddle at all, no drag what so ever off the peddle, I'm very impressed so far! For those people thinking of a set Strange brakes, go ahead and bite the bullet, it is well worth it!!!
-Coleman
-Coleman
*Update*
-Coleman
-Coleman
*Update*
-Coleman
-Coleman
It will probably see about 100 miles a week when it's all lined out. weekend cruises, evening drives, that kind of stuff. Lots of strip time though.
-Coleman
I'm running a 72 corvette power master but finally got them to bleed out but now I'm having an issue with unless I keep my foot on the gas pedal to allow more vacuum the truck won't stop at idle I'm only running abt 4 psi vacuum
