Sneak Peak (The Money Shot)
#341
Outlaw 10.5 Director
Thank you. The truck is an all motor 14.5:1 kinsler injected 6.0 with C5R heads backed up with a Chance 2pc converter and a Rossler th400. Basically built with a bunch of left over stuff from prior builds. It is run by a FAST XFI. Should be a fun truck to play around; it is not built for any specific class racing in mind.
Tom
Tom
It has gone 11.2 with the stock trans/conv/ECU and a hyd 427... High 9's would be nice with the new combo.
#349
Matt was a detailing fool yesterday!
Kurt,
I did not weigh the car yet but the block and heads are both solid so there wil be some trade offs. I am hoping for about -50lbs total delta from the last combo.
Tom
Kurt,
Tom
#354
Captain Double Post
there are nice drag cars and then there is that car, honest that is one of the sickest cars i have ever seen, that thing could win car shows just as easy as it will win on the track, you guys built something beyond what words can describe,killer work and good luck this year
#359
Last minute update before hitting the track this week.
No more Diaper for me...
Stenod and Gluski made this sweet oil containment pan. Hopefully I do not need it; right away anyhow!
Tom
Tom
#360
Slick! I see pans like that under VW engines because they have about 15 areas they leak from.
When and where is it running? Sunday (May 6) morning at 131 there is a test n tune before the VW event we are running at. Its usually 5-20 cars at most hot lapping. Check it out if you need some more seat time! Any vehicle can test before the 1pm bracket racing. Call and see if they can put down serious prep for you.
http://www.silverlakeforum.com/index...c,16988.0.html
