suspension mods for hooking @ the track Up front I have QA1 adjustables with 300lb springs and no sway bar. The rear has QA1s, LCARBs, SFCs, adjustable torque arm set at -2 degrees and M/T drag radials at 19-20lbs. Anything else I should be thinking of for hooking when the track is hot/cold? I will be running the QA1s at 1-2 upfront and 5-6 out back. Thanks |
A rear drag sway bar will help eliminate body roll off the line. |
Thanks for the info.. |
A drag, bar for shore |
If you can't afford the drag bar right away, but an airbag in the right rear spring. |
Z-rated94... if you are saying put an airbag in the right rear (passenger side) spring do you want that side stiffer? If so, why can't I tighten up the shock to 6 vs 5? Also, which drag bar do you recommend? I do drive the car to the track 40 miles each way. Thanks |
The bag acts like a slightly stiffer spring on only one side, you still want the shocks to take the hit and act the same. The bag is kinda like having a stiffer anti roll bar on just one side keeping the car from rolling over. |
thanks.. are the air bags the same and what (appprox) pressure should it be inflated to? |
© 2024 MH Sub I, LLC dba Internet Brands
