Drag Racing Tech
My nitrous assisted 99' Z28 build
Old 03-15-2010, 08:37 PM
cbra-klla's Avatar
Default My nitrous assisted 99' Z28 build
Thought i would start a thread at least since i havent been working on the car the last few weeks......
1999 Camaro Z28
MOTOR
383ci stock block LS1
Eagle crank and rods
Diamond 10cc dome nitrous pistons
custom hydraulic nitrous cam 24X's 25X's
Caddy lifters
Dart 225 heads
Yella Terra rockers
ported Victor Jr. intake
Accufab 4150 throttle body
Hooker 1.75" longtubes
Meziere EWP
Afco radiator
13.75 to 1 CR
POWERADDER
NX Gemini Twin 4150 plate (up to 300HP)
Cold Fusion Standalone fuel system
DRIVETRAIN
Powerglide transmission with aftermarker gear set and TCI pro brake
Coan custom nitrous converter
Coan Reactor flexplate
Moser 9" rear, 4.11 gears
SUSPENSION
Spohn LCA's
Spohn rear drag bar
Sphon Adj. Torque arm
Sphon adjustable panhard bar
UMI subframe conectors
Competition 3 way rear shocks
BMR tubular k member, upper and lower a arms
Madman manual steering rack
Madman travel limiters
Strange front coilovers (to be ordered)
Aerospace front brakes (to be ordered)
Valley Performance in Princeton, WV has done all the motor assembly and machine work for me. Justin is great to work with and really knows his stuff..
This car used to be a heads-cam nitrous 6 speed car that ran a best of 6.7 and made 540rwhp...I soon tore that apart and built a 370ci iron block motor with a D1SC Procharger. Due to an upcoming wedding (that never happened ) i sold that combo before it was even installed.....then came a cam only motor that made 390rwhp on motor...I then realized that wasnt gonna get it!!
__________________
cbra-klla's Avatar
I cut the upper radiator support out, boxed it in, and made a removabble support that will hold in the Afco radiator..this way the motor and transmission can be removed and reinstalled through the top very easily
Car now has an S&W 8 point roll bar, along with 2 Kirkey seats, and a removable Grant steering wheel.. Power steering, HVAC, and all other non essential stuff has been removed.. i mean who needs that **** in a street car anyway??
Plans right now include a Glasstek extended cowl hood, and Prostars with MT 275 drag radials.
