lt1- 6 liter swap wiring questions
so i have a 94 lt1 and i out an lq9 in it with a 2001 engine harness but the chasis harness is driving me nuts im not sure exactly what it came off of.. it might be a firebird or trans am harness nut these are the four connectors givin me trouble they are located right under the steering cloumn and could possibly connect in that area so any help would be appreciated thanks
first pic, gray 2 wire connector: Brake Light Switch C1
blue 4 wire connector: Stop Lamp/TCC Switch Connector C2
if you can get better shots of the other connectors, that would help. that or type out the way they appear.
guessing here, blue 8 wire connector last pic:In-Line Connector C211 (has to do with tps and throttle relaxer motor?)
last pic, gray? 10 wire connector:In-Line Connector C212
i can post schematics of the connectors if you want, hope this helps some.
C211 - (8 cavities) Forward lamp to traction control module jumper harness, under the left side of the IP, near the kick panel.
the other one seems to be c212, which would make total sense
C212 - (10 cavities) Forward lamp to traction control module jumper harness, under the left side of the IP, near the kick panel
let me know if you want the other two connectors as well or anything else for that matter
