Critic my M6 launch
M6 cars NEED adjustible shocks, most likely D/A shocks. I am going to see how far I can go on Singles, I may get a 2 step to compensate but we will see.
I dusted my first Tru Trac due to not having line lock and the track not putting down enough water.
Also yes, it makes a tremendous different for the 1/4 mi, you will notice a handling diff BUT when a true rear drag bar goes in, the car feels like it has a Front sway again.
So for the cost of a SLP line lock, some wire, and time installing the line lock and removing the front sway, you may see a tremendous different in weight transference and the ability to safely heat the tires.
I'd just start with a better burnout and go from there. If you don't get the line lock installed in time, you can always jump on the brakes (not the best choice but it works). I'd definitely get some more passes in before the shootout to try out different things.
On a side note, what clutch are you running? My clutch is on its way out so I'll be needing one in the near future. It doesn't like my 4k launches.
And of course, dry the tires off before lining up
And WSsick that is the stock clutch and do not know why it didnt fly apart, good thing it didnt since i drove it there. I did just dump it and next time will Dump/slip it and give that a try. Waiting on selling a part so i can buy a Monster and tick MC. Thanks for the help and anymore info let me know. Hell I am running at the shootout for 12.0 maybe i just do more weak burnouts and be competive, but still probly wouldnt be good enough.
Do you have a rear sway bar? A stock one would be better than non if not. I put a UMI Drag Bar on mine and the car drives like a dream. Tires dont rub, car corners pretty good for having a spool. One thing to keep in mind..Dont change a lot each pass. This is why 6 speeds are hard for people..Ohh **** I spun off of a 6000 drop..lets back the 2 step off and change air pressure and front and rear shock settings..NO..One thing at a time. Get videos and go off of those. I watch mine all the time when I have nothing to do. Also I take notes on teh back of my slip everything:
Example..
Launch Rpms: 6200
Front Shocks: Left 2 Right 2
Rear Shocks: Left 6 Right 6
Tire Pressure: Left 12 Right 13 (before burn out)
And just keep track from pass to pass and see what works..
I was cutting low low 1.7s on Radials, Factory Shocks, and no rear sway bar..I cant wait to get back to the track now with radials. The Bias Plys are scary and washy..I dont like um and I drive my car a lot so a Hoosier Radial works great for me!! Car 60s great with them but anything past 1/8 I dont like them.
