How much ET gained from 150 hit of dope?
I am at 95 right now on motor in my 89 RS(1/8th), race weight with me is about 3500ish. It is a 6 speed with 4.30 gears and the LQ4 has a Trex cam, i am just wanting to see how much MPH i can gain from the 150 shot plate kit that is going on the car as soon as i get a fuel cell for the nitrous system.
This is carbed with a Vic Jr intake so i will probably gain the maximum that i can with the kit, but is 105 MPH in the 1/8th possible? Or is that too much? I have never sprayed a car that trapped 95 in the 1/8th and i know the faster you are going, the less you start to gain with additional modifications.
Trying to judge how i might stack up against the buddies with some juice, LOL.
Race your car!
I think my car with the old n/a converter, which was getting it to 10.5 @ 3600 on motor would run about 102 to the 1/8th n/a, when I first started hitting it the car would go about 112... I changed the converter to something a good bit tighter and it didn't pick up anything to the 1/8th in et but it did pick up about 2.5 more mph (getting it into the high 114's)... out the back it gained a TON though... enough to drop the ET's about 3 tenth's and up the trap speed over 5 mph.
EFI setup as well.
Converter, and how it reacts will have a large impact on the gains you will see.
EFI setup as well.
A ton will depend on your short time. I only ran the car a few times with the bottle and a 6-speed (3 or 4 passes) while I was waiting on my th400 and new motor. Never enough to get it down. I was hitting it with 100. Unfortunately, times are 1/4 mile, but it gives you some source of reference.
(Header, Lid, X-pipe 346)
NA - 12.50@115
N2O - 12.43@124
Guess what I was doing a lot of...
NA - 12.50@115
N2O - 12.43@124
