NEW FROM MADMAN & CO.!!! LS1 Header Flanges!!
We now offer LS1 header flanges in mild steel or stainless. They're available for 1.875" up to 2.125" tubing. This is the perfect product for anyone that's going to take on building custom headers. Below is a link the flanges in our online catalog:
http://www.madmanandcoracing.com/sho...spx?itemid=209
Call us if you have any questions or to place your orders!
225-673-3533
225-673-3533
Internet Mechanic
Using Multi layer dead soft aluminum, fel-pro fiber type, or even copper never make any real difference. I did find ML DS Aluminum the most forgiving but once the flange warped it was game over and that maybe a huge oppporunity but again the motor was made for so few many years its tough to decide to design and produce such a piece.
Race your car!
You needed to surface the header flange before installing them, that's why they leaked. No gasket will seal if the flange isn't flat. If you had painted the surface, and put a piece of sandpaper on a flat block of steel and sanded the flange where it mounts to the head you'd have seen how un-flat it really was, which is why it didn't seal.
That's one of those things I've done with every set of headers I've ever had... block them and make sure they're flat before ever installing them. Makes a HUGE difference in how well, or how poorly they seal up.
Race your car!
Large belt surfacer is what I used... the block is just an example of how you can check them.
Regardless... it needs to be done. Why the header companies don't just hit all of them once they're finished with the manufacturing process I'll never understand, I've never seen a header that didn't need it.
