Noob question about motor plates.
I saw a guy running a front motor plate with no rear motor plate. He was using the trans mount to hold everything up in the back. So it was just a front motor plate and a rear trans mount in the back. Is this safe or was his stuff just ghetto rigged? I would think you would have to have a mid plate.
LS1TECH Sponsor
A mid plate is nice to have u nder about 600 RWHP. over that is is a must have. You can run just front plates on a milder setup. Either way an engine limiter is a good idea.
Race your car!
I ran a motor plate with no mid plate, and ran a lateral limiter on the engine. Did it that way for over 100 passes, no problems. Poly tranny mount in the back..
water pump, I ran a mez. race pump, little longer bolts, and a gasket on both sides of the motor plate. No problems.
