LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Drag Racing Tech (https://ls1tech.com/forums/drag-racing-tech-34/)
-   -   What are the best lca's to run? (https://ls1tech.com/forums/drag-racing-tech/138780-what-best-lcas-run.html)
Got Me SOM Feb 13, 2004 10:51 PM
I seriously need help on my 60 foot. I'm only cutting 1.8's.(running Nittos too at 15-16 psi) It doesn't help that my track never preps the surface but still I'm spinning way too much .
What are your opinions and why? Is it worth to do a Spohn torque arm at this stage in the game. I'm only running 12.5's @ 108-109.
TIA :drive:
mighty mex Feb 13, 2004 10:55 PM
Talk to BADZ
he makes some BAD AZZ LCA's
The Guy in MY 99TA Feb 13, 2004 11:03 PM
YES it is worth it to do a torque arm. IMO there will never be a such thing as TOOO many suspension parts.
I like the boxed BMR lca's but, the tubulars will be better than stock. Remember to get the reloc brackets. Madman also makes some bad ass lca's along with Spohn too.
Josh S.
Fast SS on TNT Feb 14, 2004 06:55 AM
I run Spohn Torque Arm/LCA's/Relocation Brackets and Wolfe Racecraft Drag Sway Bar.....I think it rocks. My buddy Jeff was cutting 1.37's with the exact same setup.
Big Mike Feb 14, 2004 07:49 AM
From what I hear Madman has some of the best LCA's around.
http://www.madmanandcoracing.com/
xssive Feb 14, 2004 01:36 PM
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2459161702
Got Me SOM Feb 14, 2004 02:26 PM
Those Madman lca's are way different than others I've seen. Almost 500 bucks for them. ouch!
Are adjustables needed if I'm going to have relo brackets?
ttt
MUSTANGEATER Feb 15, 2004 07:38 PM
Talk to a board member named BADZ I should be getting my LCA's from him sometime this week I'll post pics of them, they are damn good. I think Horse Power Engineering sells them on their page too.
smokinHawk Feb 18, 2004 09:59 AM
yes what do the adjustable LCA do compared to the non adjustable type
and are box or tubular better?
Got Me SOM Feb 19, 2004 06:58 PM
seems like tubular are the way to go unless you are autocrossing then go with boxed.
I don't think you need an adjustable lcs, you should adjust with the relocation brackets.
Combine that with an adjustable torque arm and I think that's all you need.
Correct me if I'm wrong experts.
I might add Hal's later on to help out 60' foots
© 2026 MH Sub I, LLC dba Internet Brands
