LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Drag Racing Tech (https://ls1tech.com/forums/drag-racing-tech-34/)
-   -   HALs and 60's (https://ls1tech.com/forums/drag-racing-tech/140730-hals-60s.html)
algws6 Feb 19, 2004 11:35 AM
HALs and 60's
I have read different things on the hal setting ranging from stiff front to loose fronts from stiff rears to loose rears. Will you guys post your settings along with your 60's so us rookies can get a clue?
Fred99LS1 Feb 19, 2004 11:43 AM
I'm a rookie to with Hal's. I have stock shocks upfront & Hal QA1's in the back set all the way loose/soft. Last weekend at 32 degrees outside I cut a 1.68 sixty foot time, and several low 1.7's setup this way.
I have Metco lower control arms also, on BFG drag radials. Fred
Coach 02 A3 Z/28 Feb 19, 2004 01:24 PM
2 in the front and 4 in the rear. 1.45 60 foots. :devil:
Coach
BIGBOS Feb 19, 2004 04:48 PM
I'll offset the rears sometimes with the right at 5 and the left at 4, I will go from 0-2 for the front settings, can't really be around zero anymore due to the addition of the iron block......
Steve Burger Feb 19, 2004 07:44 PM
Do you have a 6 speed or automatic. I have a 6 speed and run 2 in front and 4/5 or 5/6 in the rear, depends on the track. Any looser than 2 in the front and the shifts get a bit bouncy gouing down the track. I would not recommend any looser than 2 in the front on a 6 speed.
2001 Pewter WS6 Feb 19, 2004 08:11 PM
0-2 in the front 5-6 on pass rear, 4 on drivers side rear. 25# in the airbag.
CamaroCain Feb 19, 2004 08:39 PM
I only have HALs up front, and I usually run them at 4 when i have the Hooisers on, 3 and sometimes 2 when i had DR's on it.
algws6 Feb 20, 2004 08:28 AM
what about the guys that run stiff up front and loose in the back?
Kent1 Feb 20, 2004 05:58 PM
2 or 3 on front with Hal shocks
6 on driver' side rear
9 on passenger side rear, no adjustments to rear shocks
have metco control arms
best time in sig
best results around 14 air pressure
red ws6 99 Feb 20, 2004 09:00 PM
I usually run zero in front and 5 and 7 on the back (sometimes 4 to 5 on the back). I have stock front springs and at least 60 lb more weight in the front end than stock car due to the turbos. Since I have no traction til mid third gear its impossible for me to say what works best.
Gary
algws6 Feb 20, 2004 09:03 PM
gary are you coming to the shootout on the 29th?
Savageite Feb 21, 2004 05:17 PM
I only have the fronts and I set them at 2. My best 60ft. so far is a 1.62 with 27" QTP's. Also rr airbag at 20 psi.
red ws6 99 Feb 22, 2004 04:24 PM
Can't make it, wont be drag racing much for a while. Still need to buy some slicks, otherwise it pretty much a waste to have to be at 50% throttle until third gear.
Whats that thing running with nitrous anyway?
Good luck, you will probably win again :)
algws6 Feb 22, 2004 06:18 PM
well find out on the 29th. it dynoed 567rwhp and 640 ftlbs of torque on a 100 shot. should be for an interesting launch on bottle off the 2 step, especially with the new hals.
© 2026 MH Sub I, LLC dba Internet Brands
