View Poll Results: Hood Pins or Dzus Fasteners?
Hood pins
15
29.41%
Dzus Fasteners
36
70.59%
Voters: 51. You may not vote on this poll
Hood pins or Dzus Fasteners?
#41
Im using aero's as well...I just havent installed them yet lol...Im still on the fence about dzus or pins as Im still researching if modifying racecraft camaro rails to fit my TA is really worth it or not...I dont see a problem with either setup but my thoughts are pins for convenience/ease of install and dzus for cosmetic purposes...thats just my opinion.
And HioSS...you are CRAZY lmao!and thats not a diss.
#42
For the record the link JL posted is for the same pins we have on the TA. You can read out the install of them here.
We also added one of these in the front between the nostrils to help support it all. Because of where we positioned the front hood pins there was a lot or movement in the middle.
Sean
Sean
Thanks for posting that up Sean...any plans to paint it to match or will it be left flat black?
#43
Chris wants to paint it sooner or later. You can paint the aerocatch pins as far as I know. Also they make a set that flush mount from underneath, which would look real nice but more work. Also a very little amount of trimming would have been needed to make an aerocatch fit between the nostrils (no trimming needed depending on placement, and none on a flush mount) but that was also a costly option since those pins aren't cheap. The only small issue with the quick latch pin is that if you press the center to release it, it will re attach. We undo the pins, then one of us will reach over and pop the quick latch and lift the front of the hood at the same time. BUT when putting the hood on, it latches itself which is nice. Any questions anyone has about our set up, feel free to ask.
Sean
Sean
#45
6 & 8 Second Club
#47
With out me.....not really fair comparison to post with driver weight. I'm usally around 155# so there is alot of guys 100# heavier than me.....fatties....lol.
Studderin it's not worth the incoveiniance to do a snapon hood to me. I've had cars with zeused on hoods and our RR BMW's was both ways and it's a pain in the *** for a 12#+/- savings. My hinges probally weigh the same as your zues rails...maybe less, I only use 1 prop shock, the latch and cable is very light and the peice that holds it is drilled up. Most of my extra weight is the hood @about 7-9# heavier.
You have a bolt on hood, this thread is about using a pin on hood, with Dzus rails OR hood pins anyway. Your drilled stuff is cool glad you like it, but removing all of it is gona be lighter. My hood setup is 25-30 pounds lighter then what you did.
CamaroRacing12, ya it takes a few hours mounting the racecraft rails. I never did it before either, but once you have them on its good. I havnt had to mess with them at all, taken the fenders and the front end off a few times, and dpnt have to mess with the rails the way the rcacrafts bolt on.. The front rails go thu the fiberglass braket with nuts on the back, so when you pull the nose off I just leave the fiberglass part on. Just undo the 4 10mm nuts on the core support studs. The 5 top push clips do nothings anymore a
It bolts everything together better. The fender/hood/front bumper body panels are bolted together tight with the hood on with the 12-16 dzues.
Max weight pin on hood is the way to go. The weight saving for money spent in really good when getting the car light. And you get a cool looking hood too,
dont forget therse brakets you dont need with a bolt on hood anymore, and the rear hood stut ones too.
http://i2.photobucket.com/albums/y11...n/IMG_5080.jpg
kinda unclear on the visuals of everything your saying tho when it comes to the install. right now i have my nose piece and my two front fenders off. im gutting the inner fender wells right now.
#48
check my build thread on early on page 4-6 I installed the rails. And Another guy did too, we put up some pics during and what tools needed. They have good directions that they come with. I think you can DL them on their site even, or ask. But I tried to get some pics during and how you lay them out, I know some guys used it and said it was a big help. Also got info on the front fender metal. I cut the rear off, I guess most don't get to, check that out.
https://ls1tech.com/forums/drag-raci...ch-diet-4.html
#49
https://ls1tech.com/forums/drag-raci...ts-please.html
#51
I have them on mine. Here is the thread on doing this.
And yeah I was wondering about how your hood came off as well...that vid is scary...glad it wasnt worse.
#52
I was more worried about the hood landing infront of the guy in the other lane, or hitting his car, since he was a still behind me. Then my car or hood.
The old lock clip that held the front center down vibrated off on my drive out to the track. So I put a different one on and went 9.89 with no problems. Then I backed that up with the 9.75, and you see the results in the video in my sig. The additional lift of the higher speeds just pulled the clip up off of the center stud, and once that was gone it just pulled everything off, the dzus fasteners Never failed. So I redid it by drilling the hole and using a real pin (picks in the end of that thread).
I sheared that off at the hole I drilled yesterday now too with a nasty backfire, but kept the hood on this time lol. Should be getting that video my friends shot soon. So I'm drilling another hole and getting another pin like I had. So I drove the 40 miles home with the front ziptied down since I didn't have a pin anymore for the front.
Here's the thread on that run.
https://ls1tech.com/forums/single-di...aceday-9s.html
#56
Race your car!
I know insurance and whatnot.. but that won't cover crap in the event of a fire, especially if it's something you did that caused it, in that case, you're likly out of luck...
#58
Fire supression system is your friend. I wouldn't put a pin on hood on a car without one. For the 600 bucks you will spend on the fire system... you could save how much $ that you put into your car....
So far you've saved 10-15# over my setup and added 20# worth of fire suppression cause you can't get your hood off.....lol
The next guy can put his hood on and off buy himself......unless he needs help......lmao
Sorry guys .....I could'nt hepl myself
#59
Race your car!
Every ounce yes. But I will put weight back in the car in the form of safety equipment all day long.
Until you've been in a car that catches fire you don't and can't understand that. And, when you have 75 grand tied up in a car someday you'll understand the value of a fire supression system.
It's coming down the pike, that they're going to be required anyway I'm sure once you get into a certain ET range.
And, fwiw I will still come in at 2800 lbs with a 25.5 cert, fire supression system and an iron block based engine, and with at least 50 lbs of ballast in the car.
Fwiw from the engine bay pictures that I saw you posted up.. you have done alot but I am 100% that there's still at least 30 lbs forward of the firewall that can go.
#60
