LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Drag Racing Tech (https://ls1tech.com/forums/drag-racing-tech-34/)
-   -   Good Enough for Mid Low 10's??? (https://ls1tech.com/forums/drag-racing-tech/1498780-good-enough-mid-low-10s.html)
06X6spdGTO Dec 25, 2011 09:32 PM
I've currently came across a LQ9 from a 2002 Cadillac w/ 317 heads. I want to install it in a 86' Buick Regal. I would like to know what would work for a budget N/A setup for Mid 10's to High 9's??
The Regal's current setup is:
406ci SBC
11.0:1 SCR
1 5/8 headers
Holley 850CFM 4150 carb
Dart Iron Eagle heads
PowerGlide w/ 4000stall
9inch w/ 4.56 gears full spool
Cage
Kirkey seats
MSD 2 Step
Trans Brake
Car Race weight is 3012lbs with 10gals of fuel and no driver.
best time is 11.53 @ 114mph w/ 1.35 60'
I currently have a spare 04 Silverado PCM with modified harness, spare LS2 Fuel Rail/injectors/ and intake from my 06 GTO maggie swap as well as a couple sets of stock 5.3L heads. Have a full spare set of ARP rod bolts as well.
So what are the best options with the stock cube Lq9 N/A??
Port and Mill the stock 317's maybe down to 66cc combustion chambers or look into some aftermarket heads??
Install a Thunder Racing TRex cam/MS4/SNL RedLetter??
I would like to use the 4th gen Fbody LT's.
Would it be better to go with the MSD programmable Timing Box and super victor intake??
Open to all ideas and suggestions. Would like to get the setup ready to go before spring!!
:usa:
transam69230 Dec 26, 2011 12:49 AM
I am thinking your going to need 500rwhp to be mid 10s and 600 to 700 for 9s. I would look into TFS heads and bigger cam to get close to 500rwhp. Or do the 317s/Ms4 with nitrous would get it done. Could do L92s and matching cam with spray also.
06X6spdGTO Dec 26, 2011 10:11 AM
Found this article on the search and was thinking if he was getting these times with less gear and off the foot brake a set of ported 317's should flow close to stock L92 and have a little more compression. Going of the Trans Brake and Powerglide should give me a little better result.
https://ls1tech.com/forums/generatio...am-10-80s.html
BADD SS Dec 26, 2011 10:39 AM
500rwhp in a car thats 3000 lbs is definately faster than mid 10's... you would be looking at low 10/high 9's...especially if the car 60's well. Seeing as it went 1.35 with the old setup, I think you wont have a problem...
get some 243 heads, a supervic/4150 tb and a big cam, you should be where you want.
BennyB Dec 26, 2011 09:45 PM
theres cam only ls1 cars that have done high to low 10's with 400-440 to the wheels so thats definetly a false statement
with a cam/ nitrous 6.0 in a 3000lb car you'll easily be into the 9's
06X6spdGTO Dec 27, 2011 09:20 PM
thinking of going with a set of these!
http://www.summitracing.com/parts/EDL-61949/
2002camaroSS Dec 28, 2011 02:56 AM
Yea that weigh in at less then 3000lbs by a long shot! His car weighs 3012 without a driver! Lets see your time slips for doing it then since its so easy!! :gtfo:
BOBS99SS Dec 28, 2011 03:26 AM
i agree, a car could make tons of power but if its not setup to run its going no where, i have seen lots of guys cam and spray there way to 10s
06X6spdGTO Dec 28, 2011 06:22 AM
FWIW I weigh in @ a staggering 170lbs. So raceweight will more than likely be under 3200lbs since im loosing the 406sbc w/ the Iron heads.
2002camaroSS Dec 28, 2011 12:46 PM
I would suggest a aluminum short block for more weight savings. Your gonna need as much weight saving as possible to get close to that goal especially trying to do it n/a stock cube! Any idea of what the 406 is making for power?
06X6spdGTO Dec 28, 2011 05:40 PM
Just off a desktop dyno somewhere around 420bhp. Probly just clone the burgers build on his 84' cutlass gbody. Has more weight with a Th350 launching on a footbrake running 10.6xET on his Lq9
BennyB Dec 31, 2011 02:36 PM
not hardly... Ive seen cars go 10.9x or better at 3100 to 3200 lbs. with the power stated above. Another example would be the fastest cam only list on this site. Take a look if you would before posting
06X6spdGTO Dec 31, 2011 04:11 PM
I just figured if RobZ could do 9.98ET in a 3100lb c5Z06 5.7L with some Trickflows and Cam I might be able to take a 6.0L that weighs close to the same with a 2 step and TransBrake on a stalled Auto to around 10.5 on stock castings with a good cam. Looks like my main problem is PTV clearance.
BADD SS Dec 31, 2011 04:37 PM
Yeah, it proabaly made ~515 rwhp though, with 138 mph traps... And it's alot more aerodynamic than the brick... I think some compression, and ligthly ported 243's is what you want...
06X6spdGTO Dec 31, 2011 06:35 PM
his car also went 9.98. Id be happy with 10.50's!! Id give the 60' to the regal before the Z06 as well
06X6spdGTO Feb 14, 2012 06:03 PM
Figured I would update the parts list with the currents parts I have gotten for this project.
First off reweighed the car with 6 gals of fuel, full race weight on the 406ci Iron Headed SBC it weighed in at 2980lbs with NO Driver. (I'm about 170lbs)
UPDATED: -02-27-12
Anyways the parts list:
04 CTSV oil pan
Stock Bottom End LQ9 (364ci)
Trickflow "AS CAST" 220 cc heads
64cc Chambers, Ferrea 2.04/1.575 valves "LS1 setup"
.660 TEA Valve Springs
Comp Trunion Upgraded Stock Rockers
Trickflow 7.500 Pushrods
TEA spec'd cam 240/244 .613 .596 109LSA 107ICL
Edelbrock 1.75-1.875" Stepped LT's with 3.5" Collectors Ceramic Coated
MSD 6010 24x Control Box
SLP Heavy Duty Oil pump (Blue Sping for now)
ASP 25% Underdrive Pulley
EWP
ARP Rod Bolts
ARP PRE 04 Block Head Bolts
GM .051 MLS Headgaskets
850 CFM Holley 4150 Carb
Powerglide w/ 1.76 First Gear and Turbo350 Main shaft and Trans-Brake
Coan Stall set to flash between 4K-5K depending on Gear, Weight, and Engine
33spline Full spool 9inch 4.56's
Vic Jr. intake
Trans Dapt 4595 mounts
JW Performance 93019LSD Flexplate
Still needing Alternator bracket, Starter Bolts, GM Flexplate Bolts
Any suggestions or comments??? Is it capable??
06X6spdGTO Feb 14, 2012 06:10 PM
Here's an old pic of the car and the engine details on the 406SBC that is currently in it:
https://ls1tech.com/forums/small-blo...ay-406sbc.html
http://i245.photobucket.com/albums/g...7367381012.jpg
06X6spdGTO Feb 15, 2012 02:43 PM
Mike @ TEA changed the cam specs up a little 2day, 240/246 .612 .612 109LSA. Should be shipping 2morrow
06X6spdGTO Feb 15, 2012 05:42 PM
Mmmmmmmm TrickFlows!
http://i245.photobucket.com/albums/g...9346744029.jpg
http://i245.photobucket.com/albums/g...9346717828.jpg
http://i245.photobucket.com/albums/g...9347131635.jpg
http://i245.photobucket.com/albums/g...9346655254.jpg
http://i245.photobucket.com/albums/g...9346624967.jpg
Fbodyjunkie06 Feb 15, 2012 09:28 PM
See sig...
And your combo is MORE than capable at 450-475 rwhp to run low 10's high 9's with a 60' in the high 1.20's low 1.30's.
My car makes 405rwhp through an unlocked 5000+stall, TH400, spooled 12 bolt, 4.11's, 28" tire with 20pounds of air. Not a dyno queen set-up by any means.
The cluelessness of some of the people on this site blow my mind sometimes.
© 2026 MH Sub I, LLC dba Internet Brands
