H/C M6 guys, what's your launch rpm and 60 ft.?
How hard do you h/c guys come outta the hole. i went to the track for the first time in my life with the car in my sig. My best time was a 11.68 with a 1.74 60ft. i guess thats arite for my first time at a track. My car traps 122mph so i know theres more in it, im just curious on what rpm you leave the light at. I was leaving around 5k rpm on a 275-40-17 mt street radial.
You seem to have all of the suspension and rear end covered.With a slick and good track prep it should go in the low 1.50s.Im not really sure a 17 inch drag radial has enough sidewall flex to bite any harder.Try to borrow a set of rims and slicks for a pass or two next time out,if you can.
Internet Mechanic
Please Review this.....
https://ls1tech.com/forums/eastern-members/988971-my-car-manned-f-ck-up-today-new-pb.html
This has been my exp.
a Heavy M6 Car making 390-400 rwhp
Has all suspension except Shock/Springs and a Heavier rear sway bar. Also will be adding SFC's
That post is a recent outing where the car did awesome.
I tried leaving harder on the next outing and discovered the car was slamming on the rear and see-sawing back and forth, the vid shows that. The nose picks up and bounces back.
For me its run with slicks, and close to off the limiter dump.
CARTEK Racing
MT ET Drag 28x10.5 15 507HP
I will launch as high as the track will hold, I have left off the 7200rpm limiter.
Usualy launch at 6500+ best of 1.40 60' usualy in the 1.43/1.42 range.
