Question for those that have converted to manual brakes
LS1TECH Sponsor
I've done the conversion, its about 10lbs or so of savings, not much...
The problem I have is the pedal is VERY hard to push.. hey , thats manual brakes.. but now I can only brake torque the car to about 2000 RPM's when before I could go up to 3400 or so with a Yank 4400 stall.
Do you guys have similar issues?
Perhaps I need to re-blead the brakes again. I do have drums in the rear.
So far, I'm NOT liking the manual brakes. I don't think it was wroth 10 measly pounds. Takes a lot of foot work to stop the car.
Magnus, I have the strange drag brakes all the way around. When I first installed them I still had the power brake booster and they were way to sensitive. I then installed the manual master cylinder and they were much better. They take alittle more pressure to work than the stock set-up but the holding power is fine, I can brake stall as high as I want.
Maybe it has something to do with the drum brake set-up you have on the rear. Also maybe a proportioning valve would help to get the bias between the front and rear right. Why do you have drum brakes on the rear anyway ?
TJ
TJ
Oh ok. Hope ya get it figured out ! Good luck shooting for the 10's My S/I days are over since the negative DA days are probably gone. The car is coming apart for the swap now. Got tons of stuff to do. I'm gonna try something differant than the norm. Hope it all works out, we'll see
TJ
TJ
Hey magnus, i would also double check the drum brakes for proper adjustment. If the are too loose then that would hurt the brake stall as well. From everything i read the drum brakes are suppose to hold quite a bit better at the line then disc due to surface area, thats what the GN guys say.
Clint
Clint
LS1TECH Sponsor
Clint, I do believe my drum brakes are adjusted properly. I've become a master at the drum brakes now. It held fine with the booster but I probably have air in the lines.
TJ, I'm not sure how I'll do on Friday, the weather isn't the greatest anymore.. If I don't run what I want to, I will do a couple of things that are left (everythings done) during the summer and wait till next fall/spring to run some new #'s.
May wanna check the rod that goes from the pedal to the master as well. We just went through this same exact prob. on my father in laws camaro when he converted, and he found that the rod was binding where it goes through the firewall due to the manual master having a deeper seat for the rod. I made him a new one with two bends in it (like an S) and that fixed it right up. May not be the same prob. but sounds exactly like what he was telling me, and easy to check.
Good Luck!
Good Luck!
Originally Posted by Hawkn01
Cool that's your problem then, drill the hole 1" higher. That should help !!
Just watch out, after we fixed his, he said he almost locked the brakes up (@120) the first run because he got used to pushing hard!
Good Luck!
LS1TECH Sponsor
Yea, I moved the hole higher and it definately helped a lot!
I'm still having braking issues though that need to be addressed. The car is not stopping like it should be.
Pedal ratio
When converting to manual only brakes, you have to move the rod attaching point on the brake pedal to increase the brake pressure. A Mopar master cylinder is the way to go.
