Simple cam only question
Searched and couldn't find a clear answer.
I know the 243s only came on corvettes, but could I be considered "cam only" if I put an unported set on my 02 Trans Am since they're from an LS1?
Corvette engines that used them would be LS6 and LS2 which would then be called "cam only" LS6 and LS2 respectably.
The 5.3 GXP Gran Prix, and SS Impala also used 243's
All this "cam only" and "stock bottom end" crap has a VERY large gray area.
Rod bolts, fly cutting, SBE vs stock cube, bolt on, etc.
Hell, I have no doubt in my mind that a man could pick up half as much as a cam swap, by doing a very nice multi angle valve job, honing the block with a better ring pack, and balancing the rotating assembly. All of which are things you'll never see once its in the car, and there's no NHRA protest/tear down procedure for these Internet "records" either.
"if you ain't cheating, you ain't winning" plain and simple..
I am cam only, w/ stock heads, stock LS6 intake. However I have BBK pulley, cutouts, tune, Volant, ported TB. I'm still considered cam only in the performance world and with the dyno guys.
Its guys like you making a huge deal about labeling yourself "cam only" that make LS guys look dumb. It is pretty common these days to mock LS guys for claiming "cam only"...
Competing for the cam only title is just going to be, who doesn't mind a giant cam, 5000+ stall, powerglide, and every ounce of weight reduction.
Once you decide that is not for you, you turn into the guy with the "Fastest cam only, half suspension, minor weight reduction, street tired, A/C, 1999 NBM Camaro Z28, hardtop, with tan interior, in the western hemisphere, with a mother that lives in oregon, and a son named Jonh"
Congratulations. haha
Please get off your high horse and quite spewing this as gospel... I knew I shouldn't have opened this thread... These labels are all OPINION... cam only could easily be defined as literally only a cam swap.
