Drag Racing Tech
i need help racing my brother.
Old 07-16-2013, 10:13 PM
"MAC"'s Avatar
as you can see $2k still leaves you a lot of choices to be made. fact is tires and a stall should be your number 1 (tires) and 2 (stall) dont cheap out on the stall after you have those two id get headers (1 7/8 LT) then get a ported TB and Intake and a tune that should do it oh and a lid as well they are cheap i got mine for $100
Old 07-17-2013, 06:24 PM
criticalx's Avatar
I have a lid
Old 07-17-2013, 06:26 PM
criticalx's Avatar
What stall would yall say get?
Old 07-17-2013, 06:43 PM
lemons12's Avatar
Call PTC (out of alabama) and ask for Lane.
Old 07-17-2013, 07:27 PM
criticalx's Avatar
with tires and good stall will it be close? i dont really wanna beat him bad
Old 07-17-2013, 07:37 PM
"MAC"'s Avatar
Stalled auto and tires is good for atleast a half a second if not more depending on the driver in your case and in my case .5 sec would be awesome lol. Thing is you have the better motor from the get go if you build it right you can beat him with ease my friend spec'd most of my upgrades for me because i used to be in your shoes so his advice was a 3600 stall for me. for you, i would do what Lemons said make sure you are clear on what you have done already like the gears and what you are looking to do with your car! everything needs to match up right or you wont be able to do anything. Good luck
Old 07-17-2013, 07:52 PM
criticalx's Avatar
we set a date to race aug 9 at drag strip. i work alot.. money not a problem. making time to do alot to car is.. so race for win and couple months later.. waxs his *** for trying to pull a slick one on me
Old 07-17-2013, 09:19 PM
"MAC"'s Avatar
if money isnt a problem then call Comp Cams and talk to them then contact AFR and get the right heads also make sure you get the 80E transmission and a moser 12 bolt thats start flanged and gun drilled and with 4:10 gears. then id say a 4000 to 4500 stall for the 80E transmission and a turbo to top it all off on 15lbs of boost then youd be sitting pretty nice.
Old 07-17-2013, 09:55 PM
criticalx's Avatar
lol well it is when u go that big
Old 07-17-2013, 10:00 PM
"MAC"'s Avatar
lol well good luck and post some pics of your build and a video of the race
Old 07-18-2013, 11:44 AM
T6Rocket's Avatar
Originally Posted by lemons12
That is easy then..
Converter- 525$ shipped from PTC with a cooler
Ls6 intake- 325$ shipped
Headers- 550$ shipped
ORY- 175$ shipped
Used set of nice DR (MTs or better) on an extra set of rims- 300
225$ left over for fluids and misc. things..
Then enjoy how much he would have to do to keep up.
Spend the remaining $225 on upgrading from used to new DR's, instead of using someone else's spent tires.
Al
Old 07-19-2013, 12:56 PM
  #32
criticalx's Avatar
Al
good point!!! I got new mt et drs 275/40 17 yesterday. new plugs and pvc put in. im fixing to take front sway bar off.. im gonna race brother tonight at strip to see where I stand.
Old 07-19-2013, 01:32 PM
  #33
lemons12's Avatar
He is then over budget however.
Old 07-19-2013, 05:19 PM
  #34
93camaro_zzz's Avatar
What is not "a lot"...
100$? 500? 1000? 2500?
Converter and tires would pretty much get that deal done.
This guy said it all.
Old 07-19-2013, 09:48 PM
  #35
criticalx's Avatar
I run a 13.460 @103.8 with drs. Hooking good but died off the line got get a stall now. Didnt get to run him started raining. So I got saved from getting beat. He run a60' 1.85 12.970 @106.01. He got a stall over the past week. he got more he said. But on that run car skipped 2nd gear.so I got step my game up alot
Old 07-19-2013, 10:38 PM
  #36
"MAC"'s Avatar
you should be faster than that on slicks and skinnies man like you said you need practice i know i do lol. if I am not mistaking the fastest stock Ls1 ran a 12.9x I could be wrong but with more practice your time will drop.
Old 07-19-2013, 11:19 PM
  #37
criticalx's Avatar
I need practice with this car.. sad part is I can get it to run faster on street tires. With drs it takes off slow like bogs or something at wot.
Old 07-19-2013, 11:41 PM
  #38
"MAC"'s Avatar
do you do a burn out before you line up? bogging down could mean a fuel issue, well it usually is for a carburetor at least. Is it throwing any codes?
Old 07-20-2013, 08:14 AM
  #39
criticalx's Avatar
No codes.. best 60 ive done in car is 2.080
Old 07-20-2013, 11:09 PM
  #40
"MAC"'s Avatar
yea man you need to work on that 60ft for sure lol i know i aint the one to talk but i know id be out there every day trying to get my 60ft down if i was gonna race my brother. best of luck to ya! As far as the other issue just give it time someone else will pop in to correct what I said or elaborate on the issue.
Quick Reply: i need help racing my brother.
