4150 TB use stock throttle cable? which bracket?
I have an accufab 4150 on a super vic EFI intake. The car has a non cruise non abs just basic 99 Camaro throttle cable in it. Can I use this or is that not possible? Which throttle bracket do I use? I hear of guys using universal carb ones and they don't line up correct with the accufab 4150.
Re-use factory cable already there. I tried brackets from local parts stores and NONE worked right. I made one work but it was only meant to survive and do its job.
CSR and summit makes parts that work with GM cable, can't remember the p/n though. Also, get the one with return spring hook or adjustable stand-up slot.
