Colonel,Beasst,Madman I need some weights of front ends etc...!!!!
I need weights for a Stock Kmember/A-arms/power rack AGAINST A PA Steel kmember w/Steel a-arms and a manual rack
And do the Hals weigh less than the stock shocks/springs? How mcuh if any?
I need total weight loss figures!!!!
I was hoping for 75lbs?
JS
JS
LS1Tech Sponsor
Re: Colonel,Beasst,Madman I need some weights of front ends etc...!!!!
75 lbs is alot. The majority of the weight is in the lower arms. With deletion of the P/S and the K member and control arms I normally get 55 lbs. If you add liteweight brakes then you could get 65 lbs.
