LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Drag Racing Tech (https://ls1tech.com/forums/drag-racing-tech-34/)
-   -   Shooting for 12's (https://ls1tech.com/forums/drag-racing-tech/1770410-shooting-12s.html)
Denom Feb 8, 2015 10:59 PM
Shooting for 12's
My last pass was 13.3 sec. 1/4 mile at 110mph. That was with 28whp less then what I currently have, and on street tires. The track has roughly a DA of 2000ft. I'll be running with drag radials this next time (mickey thompson). The car is h/c and has a little over 400whp.
What rpm should I launch at? I'm on the 10 bolt. I have my shift light set at 6200rpm
HCI2000SS Feb 9, 2015 03:13 AM
Wait...this is a head cam LS1? If so what HCI are you running?
scotty2000ss Feb 9, 2015 03:59 AM
I'd try to launch at 2500-3000 and do a quick slip of the clutch then mash it. That's worked best for me. You should easily see low 12s with a better tire :cheers:
Denom Feb 9, 2015 08:02 AM
I dunno about low 12's at this track. I've seen full bolt on 2012 mustang 5.0 on slicks running 12.8 passes there. I think the track prep and elevation kill times.
Oh, and its got patriot stage 2 heads and hotcam, full bolt on, dyno tuned.
sillysspeed Feb 9, 2015 11:56 AM
Spend some money on suspension and start shooting for 11's! 12's should be no problem at any track with your setup with good drag radials. Start saving for a better rear also
© 2026 MH Sub I, LLC dba Internet Brands
