First time at the track - the motor cut out on third pass
I am new to LS engines - been wrenching on a 327 in my '68 camaro for the past 36 years. Recently bought a 2002 Camaro stage 3 cam, stage 1 heads fast intake, Built 4160le with a 4000 stalletc... ( the cars previous owner said his best time was 11.6) first run was 12.38, second run was 12.03, Third run I was through the 8th mile and the motor cut out, I got off the throttle, shifted to OD and it picked right up. any suggestions on what to look at ??? Thanks
When I popped the hood today I found what I think is a vacuum line, coming out of the intake and plugging into a larger cylinder on the drivers side above the valve cover. not sure what its function is but I know it should be plugged in. Thanks for the reply.
