Added stall how much faster in the 1/4 mile ?
Hi Everyone. My stock 2002 B4C was running 13.29 hitting the rev limiter a few times coming out of 2nd. The trans is getting rebuilt and I ordered a 3200 Street Brawler from FTI. How fast should it be afterwards ?
video of it on the old trans
you will need sticky tires to get the benefit of the stall at the track.
The hitting rev limiter at the top of 2nd gear is a common problem usually between purposely slightly overfilling trans and leaving shifter in OD and letting it shift itself that problem will go away , its a fluid starvation issue.
Its a Common issue with the 3-4 clutch going . Doesn't matter if its in drive . You tell the Trans is a little off when driving it. perfectly functional and fast just off . Also not going to the track again without a pair of MT ET Street
