Drag ONLY 3350lb 98-02 Fbody... TH400? Glide? 4L60E?
Race your car!
Cam wise that stage 4, would be a decent start, but try to make sure the exhaust opens as early as possible, so you can get nitrous heat out.
I would look at about a 4500 nitrous built converter made to handle a 600 hp engine and 400 hp of. Itrous, that should be efficient enough for big mph and not be a slug down low. The converter will hurt n/a times the most
