Time slips-Everything look good?
72 chevelle-4000lbs with me.
lq9 engine
78mm truck intake
ported 243 heads
228/232 .598”/.598” 112 LSA +2 advance
1 3/4" headers
4l80e trans
3300 stall
4.10 gears
28" M/T s/s tires
Does this look like everything is running like it should? I do everything on HP tuners.
Thanks, Mark
What are your air/fuel ratios? What is timing set at?
I'm also thinking the converter is too tight. I have a free restall for the first year. It will be cool to see how it reacts after its loosened up!
Timing is in the mid-low 20s. I played with it until I got the most mph trap.
A/f is at 13.0. I brought it down to 12.2 and everything in between. Ran fastest at about 23* timing and 13 Afr.
Don't do that, 28 is fine. The only thing it's gonna do is help traction with a bigger converter.
I'm going to loosen up the converter up passed 4000.
