Camaro SS budget “dragcar” build
#101
Start to sub 3k weight.. SJM abs delete w/line lock
Deleted the ps cooler and installed hose for 98 z28 also replaced ps pump,lines and cleaned up all the old fluid that had been leaking for years.. and threw on a Hawks billet pulley for easy removal in the future
assumed the alternator was on it's way out from the ps leaking on it.. so grabbed at 145a kg3 off a Escalade from the junkyard
hunger games book plot
bent up some brackets and hung the tranny cooler from the upper bumper support
#102
Picked up a 8.8 w/Hiltsy mount .. work was done by Robert Maddox on the fbody pages on FB. Has Yukon 3.55 gears,Yukon mini spool, Moser 31 spline axles and a Strange 1350 yoke.
Will be going in as soon as I get my 5-3205x Spicer 1350 to 3r ujoint in the mail.
#107
Stock explorer lsd carrier with stock 3.73 gears. I reused all the bearings except the outer pinion one because it got weld splatter on the race. I did replace the clutches with the Cobra carbon kit.
Here's my 8.8 thread if you haven't seen it yet.
https://ls1tech.com/forums/gears-axl...olt-tubes.html
#108
I'm probably gonna go ahead and yank out the mini spool and replace with one of those 31 spline trac lock carriers with carbon clutches on ebay... they are only $230 shipped. And go to a 3.90 or 4.10 and possibly some of those Dutchmen axles .
#109
Ive never been a fan of my polished Racestars...so I changed that and got them powder coated gloss black
how to delete aol email account
#110
Just checked it out .. nice work Brian! I'm jealous you have the 8.8 tubes . You thinking about doin a 4.10 in the future?
#111
Couple pics with powder coated wheels and freshly painted front bumper
rise of the planet of the apes summary
aluminum chloride reactions
Meet up with a couple local fbody guys !
#113
Got tired of the cluster being lit up like a Christmas tree. Took the cluster apart and removed the led bulbs for abs inop, brake,service vehicle,asr, and airbag .
Also placed an order to superbrightleds.com for some new bulbs.
ammonium sulfate in water
check gages is on because of the fuel level
transformers 3 decepticons attack chicago
