break in the 10's theory build
I made sure my car worked before adding power. 3250 raceweight, bolt ons, and 1.52 60' got me 11.66. Added ls6 cam for more rpms, 28" tire, and nitrous (not through the shifts) and went 10s. 10.88 on a 150 and it wasn't spraying for 2 seconds during the run because I set the window switch too low.
You can hit 10’s with just bolt ons... depends how far you want to go into the car. 200 lbs falls off these cars easy. Adding a Cam will only make it easier
Sbe ls6 Btr 4 cam, cleaned up headss, fast 102, deleted ac compressor, rear seats, front sway bar on dark star wheels got me a 10.93 at 124. Swapping to tfs220's and adding a ram air shortly
