trans brake
trans brake
I have a 2000 camaro turbo at has 3.55 gears that will run 10.34 et at 138 mph on foot brake i a trans brake i can put in how much do you think it will help my time. BTW the converter is 3500
Originally Posted by 1993lt1
My 60' 1.8 to 1.85
But if it hooks off the transbrake and you're making decent boost by the time you let it go, it should make a huge difference. At your power level the car should be 60ing significantly better.
Transbrake should make the process easier if everything else is right.
