Who's running a two-step on an auto with no transbrake?
Just wired mine up (works in the garage - untested at track). Was wondering, in theory, since it is making 1/2 the power can I set rpm higher than what I typically can hold just foot braking. My brakes will only hold ~2,300 without two-step. This is a nitrous car and am trying to hold on line as high as possible without the nitrous coming on. Nitrous converter is currently flashing to 4500. I believe the converter couples at a given rpm but will the brakes hold higher? Plan is to set the nitrous activation rpm just above max hold two-step rpm.
Hope this question makes since.
I have used the MSD 2-step in my car footbraking and I've used it in other cars.
The only issue I can see is that if your 2 step RPM is set higher than you can hold footbraking alone, when the car is on the way up to that RPM target you're going to be potentially WOT there and push through the brakes, do a burnout, etc. and then you'll get to the 2-step. You may be able to half throttle it to get it up there, and then mat it.
I had always had mine set lower than I could hold footbraking so I didn't have any issues pushing through, but I'm just a bracket racer with no nitrous experience.
My $.02
My $.02
My $.02
My $.02
I will try it on my slick garage floor to test.
The main goal is consistent launches!
Good info. I was thinking, ease into the throttle, as you are suggesting, to get it on the two-step, then bump in to turn on second bulb without getting completely off the brake (it is wired to brake light switch with a toggle on dash to open/close circuit). Then jam brake and mat it.
http://www.jegs.com/InstallationInst...1/121-8733.pdf
Just make sure the car is pointing out of the garage lol.
The only concern I have with the easing into the throttle is that the 2-step needs to see you're 1/3 below the target RPM. I've let someone drive my car and they eased into the throttle and took off before the tree even dropped.
I do not have a line-lock so I think it will hold on the line on a sticky track. I will have to play with it. It only barely tried to spin the tires on the slick, dusty garage floor.
My converter is pretty close to yours in stall, my msd 2 step is set to 3400 rpm right now and the car holds fine , even with my shitty lt1 brakes, lol i think i can bump it up to maybe 3600, i do have to really stand on the brake pedal, but it stays put and no wheelspin. I use it to build 5 psi of boost, works great
