LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Drag Racing Tech (https://ls1tech.com/forums/drag-racing-tech-34/)
-   -   M6 Guys With 4.10's Inside Please (https://ls1tech.com/forums/drag-racing-tech/19107-m6-guys-4-10s-inside-please.html)
CRAGER Jul 8, 2002 12:59 AM
What are you guys running through the traps at?
What RPM and MPH are you guys at?
I was hitting the rev limiter (which is at 6600rpm's) a little bit before the trap. This was on my T/A wheels with Nitto's which I think is 26".
Thanx,
Craig.
Moose Jul 8, 2002 05:40 AM
Re: M6 Guys With 4.10's Inside Please
I was crossing the traps with 4.30's at 6600 with 27" hoosiers. Went 125.8
Bad Habit Bird Jul 8, 2002 09:43 AM
I cross the traps at about 115 turning 6100rpms with 4.10's on 26x11.50 ET streets
Sean
Hardtop Jul 8, 2002 10:39 AM
I go thru at 6000 rpm and 113+ mph. 16" BFG drag radials. MPH is a little low due to weather conditions. ET too. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Bolt on car.
Bruce
Nine Ball Jul 8, 2002 11:33 AM
I'm on 4.10s and 26" slicks (26.4" tall) and cross about 6800 rpm (7000 limiter).
Just go have Jayson raise the limiter, you are geared perfect for your combo. Its always better for ET to cross the traps past your peak HP curve.
Tony
CRAGER Jul 8, 2002 11:50 PM
Thanx guys.
Tony- I am going to Jayson for sure to raise my rev limiter and I'll change my shift light closer than 300rpms. I watched the light go off and it was a while it seems before I hit the rev limiter.
Plus this was my first time out with this combo and my 60' was terrible. The heat was horrible as well.
Peace,
Craig.
WJ SOM SS Jul 10, 2002 04:43 PM
I was pulling thru just under 6000 w/my '99 car. Basically stock w/4.10's, some control arms, airbag, 305-35x16 M&H dot's (26 3/4" tall), a airlid, Whisper ramair, ASP pulley and shortbelt mod. 12.69, 110.3, 1.83 sixty. In respectable weather in New England. WJ. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
© 2026 MH Sub I, LLC dba Internet Brands
