Super vic with stock hood?
Engine is definitely off to passengers side a little (look at the bottom of the scoop). I glasses it in and the velocity stackseals against foam when hood is shut. Even with the cowl almost completely cut out I still run the black plastic cowl. With the mounting points you see left I've had no trouble at 130 so far. When you cut that rear support out of the hood though it does get pretty weak and wants to cave in a little. I played the cut out in for support
