LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Drag Racing Tech (https://ls1tech.com/forums/drag-racing-tech-34/)
-   -   How much will BFG's help (https://ls1tech.com/forums/drag-racing-tech/19659-how-much-will-bfgs-help.html)
Savageite Sep 16, 2002 05:17 PM
Right now I have 275/40/17 Nitto's on my Torque thurstll's and I ws wondering if I get 275/50/15 on bogarts how much should that help me on my E.T.'s. The best 60 ft.I have got so far is 1.93 but the rest of the times i get a somewhere in the 2.00-2.10 range. I should be running low 12's by know but I just can't seem to hook up.
McRat Sep 16, 2002 07:54 PM
Re: How much will BFG's help
BFG do hook better, but I'd go ET street. THey weigh less, and hook consistantly.
If you're trapping 111 it will be hard to get low (12.0-12.3) 12's unless you up the power or drop some weight. You're actually running pretty good. Get some ET Streets, and skinnies and you'll be about 12.3'ish in my opinion.
Savageite Sep 17, 2002 06:13 PM
I have one problem though. I don't have a 12 bolt. My plan was to get Bogarts with the BFG's and then when I do actually get a 12 bolt a would sell the BFG's and get some E.T. streets. Also I just went 12.90 @ 112.03 with a 2.16 60 ft. so I know I have the power to run 12.30's I just can't get a good 60 ft.
AINT SKEERED Sep 19, 2002 07:30 AM
Heat the mess out of them Nittos. I pull 1.8's all day on 16 inch Nittos and a best of 1.79 with 4.10'2 and a Air bag in right rear with lakewood lca's. and front way bar unbolted on drver side.
© 2026 MH Sub I, LLC dba Internet Brands
