What size for Drag lites and M/T Streets...
I have a Trans Am and was wondering what size in the rear and size in the front is cool for the drag lites with M/T ET streets...wheel and tire would be appreciated.
Re: What size for Drag lites and M/T Streets...
15x3.5 with a 1 3/4 backspacing or a 15x4 with a 2 1/4 backspacing in the front. 15x8 with 5.5 backspacing or 15x10 with a 7.5 backspacing. run a 165 metric radial up front, and a 26x10.50x15, or 26x11.50x15 et street. you will need spacers up front if you dont want to grind your calipers. 5/16 spacers. and whether or not you use spacers in the back, you will have to grind your calipers. 5/16 spacers in the back as well
