A few sites to help you calculate what the weather will do to your HP.
6600 rpm clutch dump of death Administrator
Dyno Correction Factor and Relative Horsepower
http://wahiduddin.net/calc/cf.htm
Air Density and Density Altitude Calculations
http://wahiduddin.net/calc/density_altitude.htm
Humidity formulas
Heat Index, apparent temperature
How altitude affects humidity calculations
Relative humidity from temperature and dewpoint
Dewpoint from relative humidity and temperature
Relative humidity from temperature and wet bulb temperature
Air density and absolute humidity
Heights of cumulus cloud bases
http://www.usatoday.com/weather/whumcalc.htm
Online weather calculator of all the stuff in USA Today weather article
http://www.srh.noaa.gov/elp/wxcalc/wxcalcsc.html
Humidity formulas
Re: A few sites to help you calculate what the weather will do to your HP.
I'd be interested in getting the WeatherGuy in here and seeing which DA calculator he uses. I've seen a couple or three different ones on the web, and they all turn up different results for the same numbers. I'd like to know which one(s) are correct.
Cool list of sites, BTW. Very nice!
