26x10.5x15 et street will it fit a 15x10 rim???? summit reccomends a 8" rim in their catalog. will it fit properly on a 10" rim? |
Re: 26x10.5x15 et street will it fit a 15x10 rim???? If you happened to bead it on the wheel you would have a tire with about as much contact patch as a motorcycle tire <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> For a 10 inch wheel i would highly recomend the 26x11.5X15 ET Street or the 26x10x15 ET Drag. |
Re: 26x10.5x15 et street will it fit a 15x10 rim???? yes they will but go ahead and get 26x11.5x15. little more rubber on the ground and it looks better. I ve had both. |
Re: 26x10.5x15 et street will it fit a 15x10 rim???? I found a grat deal on a used set but couldnt get the funds up 8''s would probably fit in the wells better anyways, thanks |
Re: 26x10.5x15 et street will it fit a 15x10 rim???? 10" fits just fine in the wells...better than the 8" actually (I've had both.) I'd go with 26x11.5 with the 10" wheels. |
© 2024 MH Sub I, LLC dba Internet Brands
