Will I run in the 10's with my set-up????
check sig.
Full-weight
Slicks
Skinnies up front
3500 stall
consider 510 RWHP/510 RWTQ
Best guess. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Full-weight
Slicks
Skinnies up front
3500 stall
Re: Will I run in the 10's with my set-up????
I was thinking an 11.00, till I saw your 200mph speedo mod. That has me thinking mid to low tens. <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
Gears, 3.73. It's all in the sig.
I thought full-weight meant that your car has never gone through any weight reduction and is the same as when it was picked up at the dealer.
I don't really know my weight, but I have a factory stock car for that matter, nothing has ever been removed. Fully-loaded T/A.
I guess the only weight reduction would be the use of the skinnies, which I heard from people on this board, that using skinnies can get you .3 off your ET.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Quickin:
<strong> check sig.
Full-weight
Slicks
Skinnies up front
3500 stall
Best guess. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Well pal most of the birds I see at NED and LVD weigh in at about 3750 with driver, so with that in mind and your 510 rwhp, <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" /> perfect traction, <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" /> good weather <img border="0" alt="[rainbow]" title="" src="graemlins/gr_rainbow.gif" /> I will venture 11.33 @ 120.3 mph ! <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Good luck <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> and remember that was only a guesstimation ! <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
<small>[ February 03, 2003, 09:04 PM: Message edited by: Orange Krush ]</small>
<strong> check sig.
Full-weight
Slicks
Skinnies up front
3500 stall
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Chris ARE 360:
<strong> I would guess around 10.8-11.2
Are you locking the converter in third gear?
Cheers,
Chris </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I believe so.
Cheers,
LS1Tech Co-Founder
Short answer: You might. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Long answer... you should certainly be in the ballpark... you might have a 3700 lb raceweight, so IMO it's 10.9-11.3 territory for you.
I ran a ten with less RWHP, less RWTQ, and a much tighter PY3400E converter. And did it at a 3560 raceweight. I think you will run 10s with no problem with that setup.
Cool weather, sea level down here, I hope so!
Should know in a couple weeks <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<strong> Cool weather, sea level down here, I hope so!
Should know in a couple weeks <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Let me know when you're going. I wanna meet ya there. And if that tranny dies (or is it "when" <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" /> ) I'll hook you up with a good one! <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I may actually race too... <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> Just not sure with all the changes I'm doing.
EDIT: Oh, and I think you have a legitimate shot at 10's.
are you kidding? assuming you get a good hook and stay with it, 10.9 should be easy. then again there is nothing easy about 10 seconds...ask john ryan <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" /> i only have about 100 lbs out of my car and skinnys and welds, but added a rear and plan on running 10.9 with my mods stock heads and a 100 dry shot easily. as long as you can hook a 1.60 or better time, you will be there. with 500 RWHP through a convertor car, that is sick! i would be happy to push 380 RWHP on motor and 475 RWHP on a dry shot! good luck from a fellow FL guy! <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by gator's 99TA:
<strong> are you kidding? assuming you get a good hook and stay with it, 10.9 should be easy. then again there is nothing easy about 10 seconds...ask john ryan <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" /> i only have about 100 lbs out of my car and skinnys and welds, but added a rear and plan on running 10.9 with my mods stock heads and a 100 dry shot easily. as long as you can hook a 1.60 or better time, you will be there. with 500 RWHP through a convertor car, that is sick! i would be happy to push 380 RWHP on motor and 475 RWHP on a dry shot! good luck from a fellow FL guy! <img border="0" alt="[chug]" title="" src="graemlins/gr_chug.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Thanks. I'll do my damndist. How about if I installed a 250 shot, mid 9's??????
kkep this in mind. The heavier the car, the more likely you are to break parts. It takes a lot to get a 3700lb car down the track. But I think A high 10 is in your future.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by WeatherGuy:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by gator's 99TA:
<strong> then again there is nothing easy about 10 seconds...ask john ryan <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">OUCH!!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" /> <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
John, you better hurry up and get that turbo setup to end this nonsense <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Moose:
<strong>kkep this in mind. The heavier the car, the more likely you are to break parts. It takes a lot to get a 3700lb car down the track. But I think A high 10 is in your future.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">This is extremely true, which is why I am lightening my car. I think you should also - lightweight supsension parts and no spare/jack at a minimum. That will get you 100 pounds right there. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I would do weight reduction except for my A/C, stereo and interior. What else can be removed for significant weight reduction?
<strong> I'll let you know for sure. I'm hoping my car will be ready on Tuesday or Wednesday. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">So what's the word Lyle ? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Are U out terrorizing <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" /> <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" /> the highway's and bi-ways of FLA. yet ???? <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Orange Krush:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Quickin:
Are U out terrorizing <img border="0" alt="[burn out]" title="" src="graemlins/gr_burnout.gif" /> <img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" /> the highway's and bi-ways of FLA. yet ???? <img border="0" title="" alt="[Razz]" src="gr_images/icons/tongue.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Not yet, the slipping converter issue is still being figured out by Yank. I guess I should here tomorrow if the new converter works, it should be dynoed tomorrow.
