eliminating ABS??
eliminating ABS??
getting the billingsley 9" rear and doing away with abs and tcs, but keeping power brakes and stock calipers.
how can I get rid of the big computer thing under the hood that the brake lines go into?
does someone sell a block to mount the lines into instead of the huge stock thing?
part #?
who has them?
thanks!!
part #?
who has them?
thanks!!
Re: eliminating ABS??
Terry,
Bypassing the ABS unit is very simple. Completly remove the whole unit, tie the lines tying the fronts together and rears together and running each set to the master cyl front and rear sections. You may want to consider a proportioning valve as it can fine tune your rear to front biasing.
Regarding the TCS, I never had it but you should be able to completly remove the whole setup without a hitch.
Normal braking will be no different.
Hope this helps!
Steve
Hope this helps!
Steve
