Will these Weld Prostars fit my setup?
I have a 12 bolt rear with stock calipesr but aftermarket rotors (powerslot, don't know if it matters) The 12 bolt is a moser, the specs on the wheels are as follows. Also, will grinding be necessary?
Prostars 15X10, 5.5 BACK SPACING
or these
15 X 8 X 4.5" bolt pattern with 5.5" BS with M/T 28" X 10.5" x 15 ET Drags
or these
Re: Will these Weld Prostars fit my setup?
15x10 with 5.5 bs will stick out, but will fit. 15x8 with 5.5 bs will fit better, but fyi, our bolt pattern is 5 on 4 3/4. you will need to grind. and 28x10.5x15 will fit on the 15x8 no problem.
