Part number for Centerline Convo Pro's for F-bods?
I had this information written down before and freaking lost it <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
What are the part numbers for both the 15x7.5 Convo Pro and the 15x8.5 Convo Pro rim that fits F-bodies?
Anyone have pics of these rims on a F-body?
Would a 26x10 inch slick fit on the 8.5 inch rim without too much crowning or should I go with the 26x8.5 ET drag on the 7.5 inch Convo Pro?
Thanks going to order this week...
Chris
Chris
Re: Part number for Centerline Convo Pro's for F-bods?
Don't have the PN handy, but they are cheapest at either Summit or Jegs. It's the 5in backspace "dual-pattern". Why dual pattern? Makes them easier to sell, as they fit stangs too.
The 8.5 will stick out of the body. You might need to raise the rear of the car. The 7.5's will BARELY clear. 10.5x26 on 7.5's is pushing it, but they do work. That's what I used to run with no problems or grinding. I did see some tire slip at 12 psi, and kept pressure at 15psi.
You will need special lugs. Don't buy the closed end ones. You will need to drill them for clearance if you do.
Cool thanks man <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Going to order this week <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Chris
Chris
