Drag Racing Tech
Post Your Shocks vs. 60'
Old Dec 13, 2004 | 03:09 PM
SSnakekiller's Avatar
Default Post Your Shocks vs. 60'
Of course there are plenty of other variables, but please post your shock setup with springs and settings VS. your short time. Try to be specific if possible. Also, do you find this setup streetable?
Old Dec 13, 2004 | 03:32 PM
JS's Avatar
JS
I run the tightest setting i can along with the highest air psi.My settings are as followed,25lbs rear air bag,4 on the front shocks,50/50 comp rears,14lbs hot in the slicks.
1.47 60fts get me this setup.....
Old Dec 13, 2004 | 03:49 PM
z28racerlt1's Avatar
Best short time 1.442 backed by a 1.443
QA1's on all corners. settings. front: 3 Rear: 7 or 8 depends on track.
QA1 front springs, Stock springs in rear.
Side Note: I HATE THE QA1'S. I have tons of rubbing on the top of the inner wheel wells. I am going to step up to Afcos when I get some money. They bounce too much. I have heard that the QA1 R's fix that problem but I am not wasting my money on any of their shocks again.
Ken
Old Dec 13, 2004 | 04:03 PM
FastBlackTA's Avatar
Hals all the way around
Old Dec 13, 2004 | 04:34 PM
WILWAXU's Avatar
Stock Shocks/Struts
Stock Springs
Spohn 25mm rear swaybar
BMR Control Arms
BMR Relocation Brackets
BMR Panhard
Random Tech Torque Arm (went 1.49 on the stocker)
Old Dec 13, 2004 | 05:13 PM
SilverGhost's Avatar
Motorboater
hals all the way around, hal springs up front.
1.51 sixty, 6 in the rear, 4 up front.
Old Dec 13, 2004 | 05:16 PM
badass 2002 z28's Avatar
Hal springs and HAL R-series shocks up front at 3...cut stock springs and isolators removed with stock shocks in rear. 14psi in the slicks
1.42 60ft
Old Dec 13, 2004 | 05:24 PM
tuff's Avatar
8 SEC SLOPPY SHOT!!!
Stock shocks with lowering springs spohn tork arm and rear lower control arms et streets at 14psi 1.42 sixty ft. Still at 3500 pounds.
Old Dec 13, 2004 | 06:12 PM
NLang's Avatar
M6 car- Factory shocks, Sportline springs (previous owner's brilliant idea )
Best 60ft w/ All-Season Dunlops- 1.77 / ET streets(14psi)- 1.50
Old Dec 13, 2004 | 06:19 PM
The Juggernaut's Avatar
Hal's -3 in front 5 in back.
Old Dec 13, 2004 | 06:46 PM
FEAR THE LS1's Avatar
Front:
QA1 Springs
QA1 Shocks @ -4
Rear:
Stock Springs
QA1 Shocks @ +6
1.300 60's
Lee
Old Dec 13, 2004 | 08:17 PM
Magnus's Avatar
LS1TECH Sponsor
1.49 stock shocks all around.
1.40 QA1's all around.
Old Dec 13, 2004 | 09:52 PM
Navy David SS's Avatar
QA1 on all 4 corners. A lot of other aftermarket suspension. 3 in front; 6 in back. Best todate is 1.35
David
Old Dec 13, 2004 | 10:05 PM
FANTAZ28's Avatar
Moderator
Stock Shocks
Stock Springs
Stock Phr
Stock Rear Sway Bar
Just A Tq Arm And Non Adjustable Lca's
1.42
OH YEAH AND JUST AN LT1
Old Dec 13, 2004 | 10:25 PM
Billy the Great's Avatar
i think onyourls1 is lying its really a bbc car
Old Dec 13, 2004 | 10:34 PM
CAT3's Avatar
Restricted User
Front Hal R' on 2 or 3 w/ Hal Springs
Rear Hals on 6 to 8 w/ stock rear springs
Stock swaybar, torque arm (poly bushing)
BADZ LCA Rod ends
26x8.5x15 ET Drags @ 11-12 psi
1.41-14.3 all night long
Old Dec 13, 2004 | 10:40 PM
Thanks for all the feedback. I have a set of Bogart D10's, and I want something sticky I can use on the street (maybe weekends) and at the track. I am thinking ET Street Radial, but any1 have any other prefs? My goal is to cut 1.5 to 1.6 and push the stock rear to its limits until i have to upgrade. I know it should take some high 1.50's or slower. And the posi is an Auburn which has been great
Old Dec 13, 2004 | 11:44 PM
NLang's Avatar
I cut a 1.50 on ET streets with a 10-bolt with the factory torsen. Weight probably has some bearing on it though.
Not tough, but don't expect it to last long
Old Dec 14, 2004 | 01:08 AM
Well it will see 1, maybe 2 trips to the track per month
Old Dec 14, 2004 | 01:35 AM
NLang's Avatar
I'm right there with you...closest 1/4 strip to Destin is 2+hrs away (Alabama) so I only see a few days a month as well
Find yourself a big, unused parking lot somewhere and practice launching there with a G-Tech. It's REAL easy to weasle in this time of yr when all the amusement parks are closed It's one way to get race-ready for spring...
