Weight difference of front springs, Stock vs HALs?
What is the weight difference between a set of stock front springs and a set of HALs?
My stock WS6 weigh 8.75 LBS each.
I weighed my QA1 springs at 8# 8 oz each. My factory springs at 7# 14 oz each and with the spring perch 8# 14 oz. The QA1 springs are heavier but you don't have to use the modified spring perch or rubber mount so the weight difference is about the same once mounted.
