LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Drag Racing Tech (https://ls1tech.com/forums/drag-racing-tech-34/)
-   -   Think i'll need a 28in tire? (https://ls1tech.com/forums/drag-racing-tech/273786-think-ill-need-28in-tire.html)
TINKRD Feb 9, 2005 06:03 PM
My previous run i ran a 12.2 at 114.
This is a T56 w/ 4.10's.
26x10.5x16 ET Streets
I never looked down at the RPM's but was well into 4th gear. I'll now be on a bigger cam w/ spray.
Will I need to get 28in tires to compensate? I'd rather get advice now, before i go out and bounce off the rev limiter :eek2:
SilverGhost Feb 9, 2005 07:50 PM
M6 with 4.10 gear if you want to shoot it 150 hp+ you'll want a 28" tire, yes.
you could maybe do 100 shot on teh 26" but you'll be crossing the traps at like 7K on spray, bad idea.
TINKRD Feb 9, 2005 08:03 PM
i plan to start off at 100shot, but will more the likely bump it up to 150. I think i'll shop around for some 28's to be safe.
Caveman Feb 9, 2005 09:24 PM
Since adding the Vortech I have a hard time gettting traction with a 26" Hoosier which used to cut 1.45 60's with na. You`ll probably have traction issues also w/ 26" slicks, use the 28" for better traction + gearing.
© 2026 MH Sub I, LLC dba Internet Brands
