Any beefy torque arms that mount to the chassis that can clear 3" true duals?
Originally Posted by LowETz
I'm using BMR's new TA relocation/ Trans. member. As said above, it moves the TA off the tail housing onto a plate on the Trans. member. Has multiple adjustments. Clears my LT/X-pipe/TD setup fine.
Is this the piece you are referring to?
