I'm tring to get in the 11's With mods in sig. I've got skinny's on the frt & et streets Rr. The best I've got so far is 12.51@110.xx. The tune is not totally dialed in yet.I'm launch'n @ 3k-4krpm's. The car is hooking pretty good for the stock 3.42 10 bolt. It seems to fall kinda flat on the big end, it's only trap'n like 108 to 110 at the best. I even tried the n2o for the first time with the 75 jets in it & got 12.67. Can some one PLEASE give me ANY advice. I've not quit figured out these QA1's yet either & the sway bar was hooked up also. What should I be getting at the track. The car is also about full weight & some. :bang: |
tttttt |
take the front swaybar off,u really need a gear to be running any faster those 342s are killing u in the 60ft.u need a 410 gear to push u in the 11s |
anyone else? :confused: |
You definately need to get your car tuned man.... and if you went slower with the nitrous.. either you have something that's not good going on. What are your 60 foot times like? that would be an indicator as to how the car is launching.. without that, it's gonna be hard for anyone to really help you out. Get the car tuned properly... and get yourself a rear with some gears. You're gonna need it anyway, as that 10 bolt with e.t. streets won't last long.... |
60's are in the 1.8 1.9 area. Last year befor all these mods, just Rr susp & et streets, TRB LS6 int. It puuled a few 1.87 60's & 12.68@ 107.8. So I don't get it all this stuff & bad results! I think it's just not set up right. I have the stuff just can't get it working properly. I'm going to get it tuned next week & put the gears in. Any other tips would be greatly apriceated, Thanks. |
| All times are GMT -5. The time now is 07:29 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
