Another Drag Racing Alignment Thread
I did a search and found lots of threads, but they mostly are aimed at just front end alignment specs. What about the rear end?
(Don't worry madman, you don't have to repost the front end specs, I've already printed them out and will be taking them to the shop when I have it aligned and have them do exactly what you said )
Can`t change anything on the rear alighnment. Mine had .3 negative camber on my drivers rear wheel. There isn`t anything I can do about it unless I bend the axel tubes. I`m sure it is making my contact patch alot worse having the -.3 back there
