LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Drag Racing Tech (https://ls1tech.com/forums/drag-racing-tech-34/)
-   -   Need help ASAP w/ QA1's (https://ls1tech.com/forums/drag-racing-tech/347851-need-help-asap-w-qa1s.html)
jj_z28 Jul 8, 2005 11:42 AM
I posted this in suspension also, but I need an answer fast so i thought I would post it here also.
Just installed the QA1 front suspension on my car. Went in great and took it out to test it and when I go over anykind of bump it is clunking from the front end. So I looked at and checked over all my work and everything is tight. But when u load and unload the suspension the shock it self is moving a 1/2 inch or so. Why is this and everything is tight! Only thing I can't check is the nut on top of the shock, which should not have came loose in the first place.
Help me please, need to run at the track tomarrow.
Coach 02 A3 Z/28 Jul 8, 2005 11:44 AM
Check the top nut on the shock. What settings are the front shocks set at?
Coach
jj_z28 Jul 8, 2005 02:21 PM
Also, they are 275 LB springs and the car sits at about stock height. Now someone mentioned on here that they had the adjuster about 2inches from the top of the body of the shock or 2inches of threads left. Well I have about 3 inches, maybe a little less of threads showing, but If I go any higher the car will be taller in front then in the rear.
jj_z28 Jul 8, 2005 06:13 PM
Also, if u push up and down on the front of the car, it has the same clunk
The Juggernaut Jul 8, 2005 06:21 PM
aftermarket K member?
jj_z28 Jul 8, 2005 07:58 PM
nope, stock K-member
CamaroCain Jul 8, 2005 09:44 PM
the only clunk i have seen after install is the top nut being loose on top of the shock where the mount is, which coach suggested.
black02-z28 Jul 9, 2005 01:37 PM
If it is moving that much the top nut is all it can be. It is easy to pop it out and check it. Shouldn't be any "clunk" sounds at all...
jj_z28 Jul 11, 2005 10:35 AM
Well, I pulled the assembly out and checked the top nut and it was tight, so now what?
jj_z28 Jul 11, 2005 05:19 PM
I did some research and I'm almost positive that I am missing parts from my Generation F kit. If u could chime in and let me know what all came in ur kits to compare, that would be great.
BKHAWK1 Jul 12, 2005 08:35 AM
I had the same question about how high to turn the nut on the springs. You want them to be 7 to 7 1/2" measured from the threads up to the bottom of the spring seat nut. don't know about the knocking noise.
jj_z28 Jul 12, 2005 12:56 PM
Also, my reciept says they are R-series
rufretic Jul 12, 2005 08:56 PM
Are you 100% sure it is the shocks? Try checking to see if anything else is loose up front. I installed mine and it seemed pretty straight forward, not much you can do wrong. Mine have never clunked. I would get it back up and check everything in the area the noise is coming from, checking for anything loose. Good luck.
jj_z28 Jul 12, 2005 09:53 PM
I have checked to see if something was bottoming, checked stuff I never loosened, I even called QA1's tech line and they have never heard of such a thing and couldn't even point me in a direction. Also, I told him everything that my kit included and he said that it was all there. Would a video of the noise and maybe some footage of what is going on under neith help? I could probably do that, I'm desperate to fix this. I actually have driven and it seems fine but it sounds just like the shocks are not tight and the top of the shock is hitting the top if the fender well and making a metal to metal clunk. How tall do U guys have ur cars sitting w/ this kit w/ a 275 pound spring. Mine is maybe a 3/4 to a inch lower then stock.
jj_z28 Jul 12, 2005 09:58 PM
Also, I had Eibach sportlines in my car and it never made a clunk or anything, now it does right after I did this install w/ the QA1's. So i know the culprit are these shocks. If it was bottoming, what would it first? I have been under and watched, I have had others under and they looked to see what was clunking and no one can figure this out.
rufretic Jul 13, 2005 07:15 AM
Is it possible you got a bad shock? I know it seems like a lot of work but you could switch sides and see if the problem still exists with the same shock or the same side. It would narrow things down a lot.
cablebandit Jul 13, 2005 08:06 AM
you say not loose but when it is on the car, the spring compresses and would take a lot of tension off the shock. When it is off the car, the spring pulls the shock fully extended and it would seem tight even if it werent. Just an opinion....
jj_z28 Jul 13, 2005 12:18 PM
I've had the shock off and retightened the top bolt and there are no more threads, it is completely tight. U think those BMR shock spacers would cure this?
BubaGumpShrimp Jul 13, 2005 10:49 PM
you said there was no more thread left to tighten the nut on the top part of the shock. Did you first install the rubber bushing than the nuts, easy to mess that up(i almost did it) and that would explanin why you could move the shock up and down. How much up and down movement do you have 1/2" or so, i would say the bushing is installed wrong...
jj_z28 Jul 14, 2005 12:23 AM
rufretic: Both sides clunk equally.
© 2026 MH Sub I, LLC dba Internet Brands
