front tire psi?
front tire psi?
so i have my rear tires at 30psi and the fronts at 35psi.. il be going to the track tomorrow, im wondering if i should have my fronts with more or less than the rears? does it matter?
Originally Posted by gator's 99TA
. all you are doing is hurting the tire by over inflating it
The tire pressure rating only refers to what is the max safe pressure allowed on the tire, it is not in reference to what is actually needed on the car. Pressure is also increased when the tire is heated.
You can use optional gasses to fill the tires such as nitrogen or argon as it does not expand to the extent as the typical compressed air-filling stations air filled tires will.
Steve
