LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Drag Racing Tech (https://ls1tech.com/forums/drag-racing-tech-34/)
-   -   29's and bigger in here! (https://ls1tech.com/forums/drag-racing-tech/432080-29s-bigger-here.html)
Carbed4thGen Jan 5, 2006 10:13 AM
Ok guys I've wondered this and havent truly found out yet. I was wondering if running a 29 or bigger tire is a minitub needed? This is assuming running on a stock rearend with stock backspacing (7.5) or maybe a 2 inch narrowed rearend with 5.5 inch backspacing. Anyone done it with the stock tubs? Anyone have pics of it? Thanx AGAIN! :bang:
The Juggernaut Jan 5, 2006 10:26 AM
I run 29's , no mini tub needed.
Carbed4thGen Jan 5, 2006 10:40 AM
Awesome to know what bs and all that are u running? Just have to trim the fenders a bit? Did you have to hit the inside at all?
Slow Z28 Jan 5, 2006 02:10 PM
i guess the width is a big thing to look at. are you running 29.5" W tires like the biggest tire allowed for the LS1tech EFI Nationals? Or are you just wanting to run a regular 29x9" slick.
6secNaLs1 Jan 5, 2006 03:13 PM
why do you need such a big tire
Ed Wright Jan 5, 2006 04:17 PM
I use the 30" X 9" radials used by the NHRA & IHRA Stocker eliminator cars. No mini tubs, just the fender opening re-radiused. Stock width rear, etc.
Slow Z28 Jan 5, 2006 04:20 PM
Ed,
you are talking true radial right? how much growth if anything do they have? anyone know how much growth a regular 30" slick would have?
Ed Wright Jan 5, 2006 04:35 PM
Originally Posted by Slow Z28
Ed,
Yes, true radials. They grow very little, if any. They hook like crazy.
6secNaLs1 asked: why do you need such a big tire?
If you can hook your car on short tires, you don't need them. I couldn't.
Good luck, Ed
The Juggernaut Jan 5, 2006 04:55 PM
I ran 30x9 Goodyear radials,they were hit or miss.Didn't spend much time with them,
hard to dial the car in on an inconsistant tire. Not much growth.
Slow Z28 Jan 5, 2006 05:06 PM
Sean what are you running now? And what were you running with this time:
Cam only/150 shot(stock long block) 9.643@138.39 (1.364) DA +1178
needing a larger tire since i'm tossing the 4.30's back in my car.
BTL FED Jan 6, 2006 06:39 AM
I run a 29.5x10.5x15 but I am minitubbed because I wanted the tire to tuck in more, so I could lower the body to where I wanted it.
Rear Narrowed 3" per side, Weld Alumastars 15x10 w/ 5" BS, MT 29.5x10.5x15
http://www.webpointusa.com/images/cu...lery/front.jpg
http://www.webpointusa.com/images/cu...llery/back.jpg
http://www.webpointusa.com/images/cu...initub%202.jpg
http://www.webpointusa.com/images/cu...icomplete1.jpg
Carbed4thGen Jan 6, 2006 09:24 AM
Ya I plan to run around the 29.5x10.5's so as long as I should be fine with them then I guess I'll get to ordering. and big tires equals big gears and big RPM's. Plus the traction should be nice with big HP and TQ numbers :devil:
NASTE_SS Jan 6, 2006 10:11 AM
I run a 29.5x10.5x15 but it is a 12inch rim which in my opinion is the only way to go if your going really fast. The 12inch wheel gives you better traction and bigger foot print the whole way down the track. I have a billingsley fab 9" narrowed 3" on each side, and i run a 15x12x6" bs and it tucks great in the wheel well.
Carbed4thGen Jan 6, 2006 10:15 AM
Any wheel well "adjustments" for that? can you maybe send me some pictures of that?
Slow Z28 Jan 6, 2006 02:16 PM
We definitely need some pics of a 12" rim on a 4th gen. don't think i've seen any but I know the Wolfe minitub kits were designed for that. atleast that's what i remember reading about.
chris
The Juggernaut Jan 6, 2006 02:29 PM
I ran and still run Hoosier 29x10's, they work really good for me.
silverZ98 Jan 7, 2006 12:14 AM
will a 28x12.5x16 et street work with out cutting up things?
Hawkn01 Jan 7, 2006 01:16 AM
I run the 30x10.5 Hoosier on my car. Standard length rear with Bogart 15x10 Alumalites with a 7.5" back space, no mini tubbing.
http://i35.photobucket.com/albums/d1...out9-17-05.jpg
http://i35.photobucket.com/albums/d158/hawkn01/lt11.jpg
http://i35.photobucket.com/albums/d1...n01/RAM014.jpg
WILWAXU Jan 7, 2006 01:20 AM
That car looks vaguely familar ;)
Slow Z28 Jan 7, 2006 09:34 AM
man, i'd figure with the 30" tire and no minitub that you'd be having a wicked rake to the car, but it looks pretty damn good. any close up shots of the wheelwell mods at the front and back to make the tire fit?
Chris
© 2026 MH Sub I, LLC dba Internet Brands
