Drag Racing Tech
Abs delete installed and now car won't start
Old Mar 19, 2006 | 09:10 AM
30thz's Avatar
Default Abs delete installed and now car won't start
I installed the SJM ABS delete yesterday and bled the brakes and tested the system all was good. I got up today to adjust the valve and after starting the car three times with no problems, it won't start again.
I got power going to everything but I get no cranking? Checked the fuses and connections and found nothing. Anyone have any ideas?
The security light is not on so I'm pretty sure it's not a VATS.
Thanks in advance.
Old Mar 19, 2006 | 10:44 AM
mvonada's Avatar
Give Steve a shout at SJM, he will know.
Old Mar 19, 2006 | 10:46 AM
30thz's Avatar
I plan on that Monday if I can't get it figured out.
Old Mar 19, 2006 | 12:21 PM
SJM Manufacturing Inc's Avatar
Removing ABS shouldn't have any bearing on it, unless you removed a fuse that controls the PCM...check the fuses again, see if you have spark.
Old Mar 19, 2006 | 12:31 PM
chpmnsws6's Avatar
This is captain obvious, but is your battery dead?
Old Mar 19, 2006 | 03:48 PM
30thz's Avatar
You ain't going to believe this but the starter was bad. It just happened to **** the bed as soon as I got the ABS delete done. Just my dumb luck I guess.
Steve10 the ABS works great holds the front down nice when heating the tires. And braked nicely, even when slowing down from a 120 mph.
One other question I know the ABS light will be on until I pull it but is the "brake" light suppose to be on?
Old Mar 19, 2006 | 03:52 PM
TS6's Avatar
TS6
Yeah, my brake light stayed on too. Its normal.
