who is running the Meziere race pump?
If your running this pump what hose did you end up going with? Getting it here in a few days and I also believe that I will need a outlet for it as well.
Thanks
Thanks
It depends on the lower hose flange. To my suprise the lower hose flange did not come with the pump and has to be ordered. I could not find a hose for the 1.75 neck that would fit the stock radiator.I ordered a 1.50 neck and it was easy to find a universal hose at the auto parts. I beleive that the radiator neck is 1.25 inch outlet and with a water pump flange of 1.50 you will need to measure the length. The hose on my car is 21" long 1.25" on one end and 1.50" on the other.
Good luck
Alan
Good luck
Alan
I'm runing one also. for the upper hose I just went to the auto parts store and they let me look through all of their hoses until I found one that would fit well. it sill required a little triming but works great. the only reason I really needed that was because I didn't want the power steering cooler in it anymore.
for the lower hose you need to order the inlet fitting seperately. it is p/n WP1125 from meziere for the 1.25". that is what size the radiator outlet is also. I just got a flex line 1.25" hose at NAPA and it 'bolted' right up.
I am also running no thermostat and having no problems.
I ordered a upper hose without the powersteering cooler in it.. No one stocked it but napa will have it tomorrow. As for the lower that will be here tomorrow as well. Just waiting for the lower inlet to get here from Meziere paid extra for the shipping..
Thanks
Thanks
