autometer gauge to cylinder head adapter
vette=lack of penis
I am converting the car to all autometer gauges and have run into a problem with the electric sending unit for the water temp. I appears as if the factory thread pitch for the original water temp sender in the head is machine thread with a gasket. The autometer stuff is all NPT. I do not see a adapter on autometers website. I know that I am not the first person to do this. Any help to resolve this would be great. Thanks ahead of time.
M12x1.5 to 1/8"NPT
Equus Metric Adapter Kit #9848 from AutoBarn
http://www.autobarn.net/eqoilpreselt.html
Originally Posted by 1QUIKWS6
Bryan is correct. Also make sure that you thread the gage sending unit into the adapter first - then thread the sensor/adapter combo into the block.
The adapter has VERY thin wall thickness due to the sizes it is converting. If you put the adapter in the block first - then thread in the sensor - the sensor will tighten in the adapter then start to turn the adapter tighter than it needs to be into the block (due to the NPT) - where upon it will snap off!
I was very careful when I did mine but did it in the wrong order and it did snap off - luckily there was enough sticking out that I could get a hold on it to turn it out of the head - otherwise I would have been screwed.
